One of my (medical college) class mates had the front wheel fall off his rear wheel drive car. Fortunately he was making a low speed turn on campus at the time so the car slid to a halt and "no harm done". It had been making "a bit of noise for a while" he said.I'm convinced that that is entirely possible. There are folks who would ignore the noise and not do anything about it as long as it still stops, and then probably say "oh, the noise just started the other day". I know somebody personally who drove for months with a failing CV joint that made a gawdawful noise akin to rocks in a garbage disposal going around corners. Told him he'd better get that fixed before it fails completely and leave him stuck on the road. Guess what happened a couple months later? First thing he tells me is "This thing failed and left me stranded on the road with no warning!". I had to remind him that I told him months ago what that noise was and what would happen if he didn't get it fixed. "Oh.".
I think it's real also. The metal backing plate of the pad is larger than the wearing surface, so once all the wearing surface was gone the metal backing plate started chewing away the rotor, including the part nearest the center which is closest to the hub. Closer than the wearing surface would be. It's visible as such in the first photo.The pad is closer to the hub further down, like the nine o'clock position if you were looking face on.
You're suggesting, by design, that the brake pad "rubs" the hub face diameter ?The pad is closer to the hub further down, like the nine o'clock position if you were looking face on.
Was it really worn down to the cooling fins, and they didn't know it?View attachment 112668
I have no spot in my brain for this. Could someone actually drive like this and NOT be aware something is amiss?
