Have a customer, generally a pretty good guy and seems reasonably intelligent. We serviced his transmission on his 2005 F150 back in June.It had about 100k miles on it at the time of service. This weekend, he was towing a car trailer, in rough terrain. He started blowing transmission fluid out of his pickup. From our initial diagnosis, it looks like it is a pump and/or pump seal.
He is of the opinion that servicing the transmission caused the problems. "I was always told that if you change the fluid, you will have problems. That's what caused it. I should never have had it serviced".
We tried to explain that actually, had he had it serviced regularly, especially since he tows a car trailer, he might have avoided the problems. Our explanations have fallen on deaf ears. I can only think what his excuses might be after we repair his transmission and he has problems down the road from failing to service it regularly. I just hope his engine doesn't blow within three months of an oil change. Of course it will be our fault because we "just serviced it".
