I just bought a 2017 Hyundai Tucson with all wheel drive. Can someone explain for me how this system works? Thank you
Change your rear diff oil ASAP. I had very dirty rear diff oil at 2,000 as I sport drive my AWD lowered Kona. I suggest changing at the 5,000 sport driving and 8,000 if you drive like a older mom and dad when buying a new AWD car/suv. Your diff has 1/2 Qt of oil for all those AWD clutch plates, that makes the oil abrasive. I changed it again at I think 7,000 miles and it was dirty again. When I changed it out at 15,000 it was pretty clean. So with some hard sport driving it takes a bit to get the clutches fully broken in and it doesn't take much to have black rear diff oil with 1/2Qt of oil and a bunch of clutch plates. My wife's Rav4 had very black oil at 22,000 miles and I did 2 flushes and it is running cleaner now too, again ...a 1/2 of oil in very critical area that needs some much needed maintenance in the beginning of life.
The oil for the diff and the clutch pack are seperate. The oil you can change is the diff oil
Ok I looked at exploded view and you maybe right. .
Yes, they are light duty and are not engaged full time unless you start slipping a wheel or if you put the car/CUV into "sport mode." This is where it does go into a full time 95% fron 5% rear mode. At least Hyundai and my wife Rav4 does this. You feel this when towing, you feel and hear load only on the front diff but when you put it in sport mode you feel load go back to the rear diff and off load the "load" from the front. It says this way 100% of the time in sport mode. In my Hyundai it also stops the DCT from going into 7 gear. A gear you never want to use in towing anything remotely heavy.
We're thinking of a '20 or '21 Kona . Just finished looking at online ownwers manual of how the AWD works . Similar to that of the Pontiac Vibe and Toyota Matrix with AWD .
In our 2019 Santa Fe the rear diff is engaged every time you accelerate from a stop - - regardless of what mode you are in. Once you are at your cruising speed it disengages.Yes, they are light duty and are not engaged full time unless you start slipping a wheel or if you put the car/CUV into "sport mode." This is where it does go into a full time 95% fron 5% rear mode. At least Hyundai and my wife Rav4 does this. You feel this when towing, you feel and hear load only on the front diff but when you put it in sport mode you feel load go back to the rear diff and off load the "load" from the front. It says this way 100% of the time in sport mode. In my Hyundai it also stops the DCT from going into 7 gear. A gear you never want to use in towing anything remotely heavy.
