Hi, I'm new to the board but have been reading posts for weeks now, been getting AWESOME stuff from you all.
After reading through some of the posts on this subject, I was wondering if I might experience any starving of the transmission fluid, or low pressure because of this setup, or anything of the sort?
I drive a 98 Honda accord 4 cyl and have recently installed a fluidyne multiflow cooler with a b&m remote transmission filter kit. You can see the remote filter pretty plainly here in this pic, and the cooler is on the left of the pic right behind the bumper
I really liked the idea of the remote filter due to the lack of a stock unit and I have not experienced any problems after driving on this setup for a little over 700 miles so far, but I want to just make sure that I won't be seeing any later on and don't want my imagination to run away with me.
I have the fluid going through the radiator first, then to the filter and then the cooler and am using redline ATF. The fittings on the cooler are 11/32 and were exactly the same fittings as were on the original points coming from the return line on the radiator. The cooler is a 6 pass with 14x6.5x1 dimensions.
Any comments would be greatly appreciated!
[ August 20, 2003, 07:10 PM: Message edited by: dham ]
