Auto-RX comparison on chassis dyno
It would be totally useless. Dyno runs on a car can have a 5hp difference with the same car, on the same dyno, in the same day. So Doing it on different days its going to be off even more. To really see any difference youd probably have to make more HP than AutoRx would provide you with if at all.
It all depends on how bad off the vehicle is. As shown in the above link, I used a GTech to check my Festiva's progress and it picked up a whopping 45% increase in wheel HP(38 up to 55), but that was just bringing it back up to factory spec.
I think a larger engine is more likely to show improvement with Auto-RX that can be measured on a dyno than a smaller one. A larger engine has more cylinders to have gummed-up ring packs, and more horsepower to loose due to the effects of the dirt which Auto-RX removes.
If, hypothetically speaking, each cylinder with a gummed-up ring pack loses 1% of the horsepower...that means my 225HP 5.0 has lost 8% of it's factory-rated horsepower, or 18HP!
That sort of difference *SHOULD* show up on a dyno. On the other hand, an 88HP 4-cylinder that lost 4% of it's horsepower would only have lost 3.52HP, and that wouldn't likely show up on a dyno due to the margin of error.
If we're talking about smaller engines, the effects of sludging/gummed up ring packs/etc. that Auto-RX cleans up are likely to be less, and therefore, less likely to be outside of the margin of error of a dyno.
When you have a test instrument that has a margin of error, you scale up what you are testing so that it is out of that margin of error. That is why I think a larger engine (with a LOT of miles on conventional oil) is ideal for a dyno test of Auto-RX effects.
Has anyone ever done a before and after chassis dyno test of the Auto-RX treatment only, to check rear wheel horsepower change? The kind of test they do on some of the car shows, such HorsePower TV and Trucks!.
I just started the Auto-RX on my 1988 Mustang 5.0 with 158,000 miles..I'm not sure what the local shop charges for a dyno run, but if it's not terribly expensive I'll consider getting one done (I've only put about 50 miles on it with the Auto-RX in and I'm not currently driving it around very much).
Ok I just called the local shop, $75 for 3 pulls, which is kinda reasonable I suppose, and it would be worth $150 to know what sort of improvement Auto-RX made...
