JHZR2
Staff member
Hi,
I just bought a few bottles of auto-rx. I want to use it in my saab 9-3, which is only specced for running on a full PAO synthetic (Mobil 1 0w-40 is the only one available in NA).
Since my driving style enables me to go over 15k miles betweeen changes, I plan to bolster with LC (which I always use in my other vehicles), and auto-rx.
I have a couple questions: First, should I be wary of any issues arising from mixing rx and LC?
Second, Id like to know a good RX maintenance dose for OCIs of, say, 10-15k miles, which is likely around when Ill plan to do it. The sump is 6 quarts, and it seems to me that maybe Id want to dose slightly higher since the usage duration is longer, so there are theoretically more things to pull from the oil (if auto rx lasts in the oil for that long).
Finally, can anyone give insight on the resultant effects if rx is competing with the esters in the oil Im using? Remember, its only a maintenance dose, so surface concentrations cannot be as high as in a true cleaning dose. Id guess that it would remain in solution and 'last' longer in a syn oil, since there is the competition for surface , and then the rx component be able to selectively remove items that show up, as they do. Is there any potential issues to having RX in the syn oil? I wont be changing to dino for the sake of Auto-rx usage, and since the engine is new, Ill only be doing a maintenance dosage to keep things clean. I just want some assurance that Im not screwing up my oil's chemistry, destroying its ability to go 15k+.
Any info would be appreciated.
Thanks,
JMH
Thanks,
JMH
