Hi,
I own a '99 Crown Victoria... I was cleaning the car yesterday: vacuuming, cleaning the dash... I also sprayed White Lithium grease on the door latches and hinges... I used a fairly generous amount on the latches, so I'm unsure if this has caused the problem...
Anyways, that same evening, the auto headlights would come on while the car was off... They would stay on for a while, then go off for a second, stay on for a while, then go off for a second, and the cycle continues. The inside dome light was doing the same as well (as it usually does when it's working right).
When I arrived home, I simply put the headlights to the off position, but this problem was still bothering me. So, I pulled out the owners manual and checked fuses. I pulled out the fuses until I came to the one where the headlights wouldn't work. It was:
Fuse/Relay Location: 12
Fuse Amp Rating: 18A CB
Description: Lighting Control Module, Flash-to-Pass, Main Light Switch
It was a medal lookin' fuse, so I couldn't see if it was blown or not. When I put it back it, the headlights behaved properly. But, I left the auto headlights off for fear that it would start up again...
And then the next day, the dome light came on a few times by itself... It didn't happen very much I think, it seemed to have no effect on the battery.
I started up the car this morning with the auto headlamps, put my hand over the photo cell, and the headlights came on - so I don't think that's the problem (Thank goodness, those are probably expensive)
Did I screw up this car with the White Lithium Grease??? Or will replacing this fuse solve the problem?
Thanks
Thanks
