I have a question that has been bothering me. Ok, I did a full mechanical exchange of synthetic aft with BG system on my car back at 174k with Mobil 1 Mercon V and I'm quite happy so far. I wanted a fluid that would be more sheer stable. At 205k, I plan on doing a drain and fill (of course changing the filter) from that point forward.
Is it ok to mix Valvoline Maxlife Dex/Mer aft with the Mobil 1 synthetic atf? I will probably just buy 4 qts of the Mobil 1 sny atf and go from there, but I just wanted to know if that is possible?
I'm very anal about my car, because just doing the drain & fill method only changes out 4qts and my transmission capacity is 11qts. That means most of the old nasty fluid will still be in there. I will probably do another mechanical exchange at 205k.
