ATF for PS pump
Scottsdale, AZ
(reposting this)
Sprintman,
Any more shuddering problems w/ the Redline ATF or have you switched to PSF? If you have switched, how's it working? Is this a problem to really be concerned about?
I've had to rebuild my p-s-p twice since '93 because of heat related seal failure.
Any other suggestions on a synthetic ATF for pump would be appreciated. Truck is '93 Toy V6, manual says ATF DexronII.
Thanks.
Hugh
Hugh,
I've been running the Amsoil synthetic ATF in the power steering of my '95 Tacoma for the past six years. It works just fine and I'm sure the Mobil 1 or Redline synthetic ATF's would also work very well ....I just kept suctioning oil out of the reservior and refilling it once a week until I had added about 3 quarts to flush the system.
TooSlick
