ATF cooler and filter install
MD
Would this method be the best application for a 2003 Tundra?
Install spin on filter to the output, supply line, to spin on filter, then to radiator cooler.
Install B&M super cooler from radiator return, to cooler, then return to trans.
That makes the most sense since the filter will keep most of the junk out of the coolers. Also, oil temp will be at it's highest there so pressure drop through the filter should be minimized due to the oil being thinner.
