If I bought a vehicle that came with a ULV / LV ATF I would swap it out (with a pan drop to inspect & clean magnets), probably with Valvoline Maxlife ATF as it's the most cost effective / available to me. Amsoil if I had the cash to spare.Honestly, if it came with ULV, that's what I would use when doing a flush or drain & fill. It might shift harder or have other minor issues with regular Dex 6 types of fluid. However, my Cadillac has the 9 speed and uses Dexron 6 and my brother has a Bronco Sport with the 8 speed (basically it's the same transmission with one gear tuned out) and his takes ULV.
highly recommend against this. with how complex new transmissions are and tightly tied to electronics, i would stay with an ULV if the transmission calls for it.I would NOT run any transmission with an ULV fluid
There is a reason they spec ULV fluid. I would most definitely not do this. This isn’t quite the Dexron VI debate where one may be compatible vs licensed. Only use a ULV fluid. If you want something non Dexron ULV licensed, many make something that they list as compatible that would probably work.If I bought a vehicle that came with a ULV / LV ATF I would swap it out (with a pan drop to inspect & clean magnets), probably with Valvoline Maxlife ATF as it's the most cost effective / available to me. Amsoil if I had the cash to spare.
I would NOT run any transmission with an ULV fluid just as I would NOT with an engine. Equipment wear and reliability are more important to me than 5% fuel efficiency and extra wear + failure. My Nissan CVT runs great on Maxlife or Amsoil (both are cheaper than the inferior Nissan NS2 fluid) and my engines that spec 5w20 / 5w30 run really well on 5w30 / 5w40 / 0w40
It’s likely the P66 it came with - so ideal for a partial changeGM ULV trans fluid at rock auto is dirt cheap. It's hard to pass up a fluid that meets spec at the price they are selling it at.
I believe the answer is fuel economy and the related sales boost. I would love to know more.There is a reason they spec ULV fluid. I would most definitely not do this. This isn’t quite the Dexron VI debate where one may be compatible vs licensed. Only use a ULV fluid. If you want something non Dexron ULV licensed, many make something that they list as compatible that would probably work.
No such thing as Dexron 6. It's VI, as in V.I.Honestly, if it came with ULV, that's what I would use when doing a flush or drain & fill. It might shift harder or have other minor issues with regular Dex 6 types of fluid. However, my Cadillac has the 9 speed and uses Dexron 6 and my brother has a Bronco Sport with the 8 speed (basically it's the same transmission with one gear tuned out) and his takes ULV.
That what we've been speccing for the new trucks.It’s likely the P66 it came with - so ideal for a partial change
IMO, with transmissions, I don’t think the whole thick vs thin fuel economy debate really comes into play. They are incredibly more complex and everything has to work just right. The solenoids, valve bodies, and everything else has to be absolutely perfect. We are fitting 10 speeds in a smaller form factor than 6 speeds years ago. Thinner fluids might just have to be present in order to properly lubricate, flow through smaller channels with the overall smaller and more compact size, and everything else.I believe the answer is fuel economy and the related sales boost. I would love to know more.
