ASTM-IV Wheel Bearing Greases
MolaKule
Staff member
Iowegia - USA
There is a standard test method for life performance of automotive wheel bearing grease.
What ASTM test is used to determine the Life of wheel Bearing Grease and how is the test performed?
25lbs thrust load at 1000 rpm's, at a spindle temp of 320 degrees fahranheit (160c), 20 hours on, 4 hours off, on/off cycle. The test goes on until the grease breaksdown to an established end point, measured from the motor drive torque.
Excellent, now which ASTM test its it?
