article says engine on during ATF drain/fill
Southeast
http://www.ehow.com/how_7224973_add-fluid-2007-toyota-tundra.html
1 Drive your Toyota Tundra around for 15 to 20 minutes. This gets the engine going and heats up the transmission fluid, which must be hot before it can be changed. When finished, park on even ground but leave the engine running.
2 Lift the truck using jacks or ramps and locate the transmission under the front of the truck cab. Remove grease from the drain plug with a clean rag and cleaning solvent. Also, wipe off any dirt or grease in the area around the plug.
3 Remove the dipstick from the filler tube. Place the funnel into the filler tube and put the drain pan beneath the tube to collect the old fluid.
4 Use the socket wrench to remove the overflow plug and the refill plugs. The old fluid will drain out into the pan. Be sure not to let the fluid touch you because it should still be very hot and could burn.
5 Wait for the old transmission fluid to stop draining. Pour the new transmission fluid through the funnel into the filler tube. Wipe off the dipstick using the rag and use stick to monitor the level of fluid inside the tube. Stop adding fluid when the level indicated by the dipstick reaches the desired point. Otherwise, continue adding the transmission fluid until it starts to trickle from the overflow tube. Note that a slow steady drip is not a trickle and, as such, does not mean that the fluid is at the desired level.
6 Install new overflow plug along with a new gasket, and then turn off the engine. Install a new refill plug with its own new gasket in place of the old one. Replace the dipstick in the filler tube and start the truck without revving the engine. Let it run for 5 to 10 minutes, then shift the gears a couple of times, finally putting the truck back into park.
7 To ensure everything is in order, examine the dipstick again and see what fluid level it indicates. Add more transmission fluid using steps 4, 5, and 6, if necessary (though the new overflow plug and refill plug need not be replaced again).
Read more: How to Add Transmission Fluid to a 2007 Toyota Tundra | eHow.com http://www.ehow.com/how_7224973_add-fluid-2007-toyota-tundra.html#ixzz20eTMVd22
I wonder why they call for it in this unit? I might let one run for 15 seconds.... maybe 20... but this doesn't seem right?
M
I wouldn't do it.
It's the fluid that keeps the pump and other internals such as pin bearings lubricated.
Multiple drain and fills are in my view the safest method of changing fluid.
Originally Posted By: JRed
You go first.
nu uh. you...
ok on the serious side--- I *am* one of those people that will run it, carefully, if I'm *really* trying to get more fluid out... for up to 15 seconds or so, at idle, in P, no load. But yes running for the duration doesn't seem right.
m
To clarify my earlier post, the Infiniti manual does require one to keep pouring in as the fluid is draining out. They mention to do it at an equal rate. For me at least, that would be a pretty neat trick.
