“LSJr said:“It’s important to use the proper viscosity designed to work with alcohol-based fuels because high fuel dilution will lower the oil’s viscosity. High fuel dilution can change the oil’s viscosity from 20w-50 to 10w-30, thus reducing the wear protection. So, in high-performance engines, you want all the protection you can get while turning high-RPM and not compromising the oil’s wear protection.
One would think if fixing the W rating of used oil was this simple, that oil companies would work with auto manufacturers to ensure a minimum amount of fuel dilution. Waitaminute…
https://www.enginelabs.com/tech-stories/selecting-the-right-oil-for-your-e85-powered-application/
