SumGuy
Thread starter
So discussing ATF for 60's transmissions has no value because they're ancient technology, but BITOG is loaded with discussions for the oil used in the presumably also ancient engines in front of those transmissions.
Regarding terminology, is it ok to say "dexron 4" instead of "dexron VI" ? I just don't see the point of using roman numerals. I also don't get the difference between "Dex/Merc" and dexron (from a naming pov). Why the mashup?
This old post has a lot of information (or opinion, maybe credible/accurate, maybe not):
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/629438/1.html
Planetary gears that run most of the time in over-drive (old 727's didn't have overdrive) and lockup torque converters (which again old 727's didn't have) are other things to consider. Some ATF's have detergent, wax, some don't.
