- Joined
- Jun 2, 2003
- Messages
- 23,587
Most German transmissions make a "turbine" or spooling up sound, which is normal. If the noise appears to get worse, it could be your perception or it could really be happening. A droning or whining noise that occurs only at certain speeds or in certain gears indicates a damaged transmission bearing, for example the main shaft bearing. A rattling, chattering, or rough noise indicates chipped teeth. Shifting down into first gear while still moving without good reason (steep SF hill and engine breaking)is generally not a great idea and I would avoid it. On an off-chance, the old BMW does definitely have a fully synchronized 1st gear, right?
If I were you, I'd change the transmission fluid and I'd also examine the old fluid closely. I found some interesting bits and pieces in mine.
