Approved oil for Powerstrokes
jamestown, pa
I am looking for feedback and updates:
I have a 97 F 250 Powerstroke with 175 K on the clock
I was running Wolfs Head 15w40 Synthetic Blend in CJ-4 However my newest shipment is now CK-4 as the published paper by Ford: This is not acceptable for Powerstrokes. Any change in this?
Options for CJ-4 Approved oils out there? My Truck has run NOTICABLILY Better on the Wolfs Head 15w40 over all the others, smoother, quieter, more pep.
What options do we have out there?
All Amalie oils blessed by Henry...
AMALIE XLO Ultimate Synthetic Blend Molybdenum Fortified 10W30 AMALIE Oil Company
Rallye Maximum Duty Plus 10W30 AMALIE Oil Company
U.S. LUBRICANTS MAXIMUM DUTY-PLUS 10W30 AMALIE Oil Company
Value Tech Maxium Duty Plus 10W30 AMALIE Oil Company
WOLF'S HEAD EXTREME-DUTY SYNTHETIC BLEND 10W30 AMALIE Oil Company
XCEL MAXIMUM DUTY PLUS 10W30 AMALIE Oil Company
AMALIE XLO Ultimate Synthetic Blend Molybdenum Fortified 15W40 AMALIE Oil Company
Rallye Maximum Duty Plus 15W40 AMALIE Oil Company
Spectrol HDD 15W40 AMALIE Oil Company
U.S. LUBRICANTS MAXIMUM DUTY-PLUS 15W40 AMALIE Oil Company
Value Tech Maxium Duty Plus 15W40 AMALIE Oil Company
Wolf's Head Extreme-Duty Synthetic Blend 15W40 AMALIE Oil Company
Xcel Maximum Duty Plus 15W40 AMALIE Oil Company
AMALIE XLO Ultimate Full Synthetic Molybdenum Fortified 5W40 AMALIE Oil Company
Rallye Maximum Duty Plus Full Synthetic 5W40 AMALIE Oil Company
U.S. LUBRICANTS MAXIMUM DUTY-PLUS Full Synthetic 5W40 AMALIE Oil Company
Value Tech Maxium Duty Plus Full Synthetic 5W40 AMALIE Oil Company
Wolf's Head Extreme-Duty Synthetic Blend Full Synthetic 5W40 AMALIE Oil Company
Xcel Maximum Duty Plus Full Synthetic 5W40 AMALIE Oil Company
For your '97 you can run anything you want, CJ or CK in the 15w40 weight. The CK specs Ford is concerned with is only with the newer 2011 and up engines. But if Wolfshead is what you like, use it with confidence.
While Ford may only be concerned with 2011 and up PStrokes and oils, their current list of approved oils dated 5/15/18 is so extensive that the topic seems to be a non issue. Lots of all the different viscosities..... 10w30, 5w40, and 15w40. CJ-4 and CK-4.
The latest 10 page long Ford Approved list.......
https://www.fcsdchemicalsandlubricants.com/main/additionalinfo/dieseloilsWSSM2C171F1.pdf
