Anyone regret their cordless electric OPE?
Indiana
I am sure the majority of BITOG will want to tar and feather me for asking such a question (and rightfully so), but how does the people with experience feel about their electric OPE?
I did a brief search on Stihl products and the cost of gas vs. electric appear to be the close, but without test driving each model, I have no idea how they'd compare. Run times can be anywhere from 30-45 mins.
I'm looking at mid tiered weed eaters and leaf blowers. Thanks.
I live in Suburbs.
I have:
Battery Lawn Trimmer & Hedge Trimmer: …… Ryobi 40 Volt Batteries
It's GREAT not getting out the 100 foot Extension Cord every time.
I can keep the yard looking a lot nicer with less effort.
Electric Leaf Blower
Will be used near the Garage Door to blow off Riding & Push Mowers.
I just ordered a 40 foot Retractable Extension Cord
As I get older, and smarter, I'll do anything to make life easier.
I have an electric leaf blower. After using it once I decided I will buy all gas from now on. No way I'm hauling out the extension cord again
Darn, I knew I was missing something. I forgot to mention CORDLESS!
If you go battery powered, go with the upper end models. I have a Worx 32 volt trimmer which is plenty for my yard in the suburbs but I could see others not being satisfied if they are trying to cut areas with thicker weeds. I've had it about 3 years without any issues. I also have Kobalt 40 volt blower (about 4 years old) which is fine for blowing grass and leaves off my sidewalk and porch but if I had a bunch of leaves to blow around the yard it would be a hassle. The new 80v Kobalt blowers are way better than mine. We bought my father in law one for Christmas and he is happy with it.
I recently bought a battery powered string trimmer replacing my two cycle gas unit. I love the new trimmer and wish I had switched over earlier. Certainly easier to use and maintain.
I have an EGO 56V push mower and string trimmer, and a Sun Joe 40V blower/vac. It's only been about a year and a half, but I don't regret the decision to go cordless one bit. I have a very small yard so I'm nowhere near running out of juice when I'm done with the job, works out perfectly for me.
When I moved to a double corner lot, I bought an 18V hedge trimmer, 18V blower, and corded weed whip.
The cordless blower barely held a charge long enough to my short driveway and garage, let alone the sidewalks. I then replaced it with a gas Hitachi, and am quite satisfied.
The hedge trimmer did fine for the 20 ft of hedges, but I recently replaced it with a 20v max B&D; a lot more power and longer life, and sufficient for my needs.
The corded weed whip was a PITA to drag a 100 ft cord around but otherwise was fine. I replaced it with a gas Hitachi and it is much better, albeit a little slow to respond to the throttle.
Keep in mind that my initial purchase of cordless units occurred 8 years ago and technology has improved a lot since then. My brother has the cordless dewalt weed whip, chain saw, and lawn mower, and loves them. I like gas equipment for things that take more than about 20 min to complete.
I just made the jump to Makita 36 volt outdoor tools. I have the blower and power head style trimmer. I am a convert. I can do everything with these that I could with my Stihl gassers.
The downside, they are expensive and you will need at least two sets of batteries (four total). If you have a big property, better have four sets. The blower goes through batteries faster than the trimmer.
Low noise
No fumes
No yanking the starter cord
Can put them inside the car/cab
Light weight
I use the blower for lots of other things now... like drying off the car. And quick little "blows" around the house.
Dislikes:
Cost.
Carrying around extra batteries.
The long term reliability of the machines and batteries is unknown. They have a three year warranty... if they last that long I will be happy. i don't expect they will come close to lasting as long as the Stihl gassers which are still going strong after 18 years.
The problem I have with batteries is they go bad no matter what.im sure batteries are expensive. Yes gas engines wear but since I started using true fuel I have had no problems starting my close to 7 year old weed whacker.
Stihl gas string trimmer, 14 years old, still runs great.
Echo gas leaf blower, 12 years old, runs flawless.
I do not own *ANY* battery powered anything that has batteries that lasted longer than 3-4 years.
That right there makes it worth the difference.
DeWalt cordless string trimmer. Love it for my suburban lot.
Same 20V battery as the drill/driver etc......
I only question why I didn't buy it sooner.
Saw a robot grass cutter wandering around Princess Street Gardens, Edinburgh, when I was back in The Yook this summer.
Perhaps whoever used to cut the grass for a living is regretting that one?
I'm not buying them unless I can get a deal.
1) Snapper 82V leaf blower, 2Ah battery, and charger, in Oct., off-season refurb for $150.
2) Got spare 4Ah battery for $190. Turns out this is too heavy and awkward for the leaf blower. Regret.
3) Got Kobalt 80V hedge trimmer, 2Ah battery, and charger for about $16 OOP. Same mfgr. as Snapper (and Greenworks), but pack and charger are keyed so aren't interchangeable. Ridiculous vendor lock-in. The torque of the motor is a good match
for hedge trimming - can run it at a low speed and it'll cut through things rather than stalling.
- Last week leaf blower bucked when I pulled trigger, and died. I thought that was it, but 15 minutes later it worked again.
I can't find a service manual nor schematic online for it. Gives me feeling it'll die earlier rather than later.
Charger does soft-start charging of battery, and blower soft-starts its motor, so I like their treatment of surge current.
The 2Ah pack (I guess) is 18 18650 Li-Ion in series (18S1P). Over time they have to charge and discharge at different rates,
so the pack will become unbalanced. Not sure what I'll do when that becomes a problem.
The only downside of using gas equipment is that you will have no valid reason, as far as the wife is concerned, to buy new toys every few years.
I wouldn't say I regret my electric OPE, I currently have an entry-level craftsman string trimmer/edger and a HF electric blower/vac.
I had 2-cycle gasoline versions of each of these and while both were more powerful, 2-cycles and I don't seem to get along, I can't keep them running more than a year and a half. I blame ethanol.
D'oh! Didn't read.. these are both 110v, not battery. I'd opt for 2-cycle again over battery powered.
