Anyone Here Own A Dueling Tree ?
Lake Havasu City, Arizona
I've been playing around with the idea of getting one for handgun shooting. It would eliminate the need to set up and then take down paper targets. And would add a little more fun, as opposed to paper punching.
It would also cut down on the amount of crap I have to haul to the range. I could just toss it into my truck, and set it out there when I arrive. A can of contractor orange spray paint, and a few black pasties in the center, and it would also serve fairly well to sight in on.
I'm thinking about this one. It's simple, and it's made from 3/8" thick AR500 steel. They sell extra plates for it, should the need arise. I don't know if a .22 L.R. would have enough soup to swing them, but I mainly want it for my bigger calibers.
If anyone has one I would be interested to hear about your experiences.
https://www.amazon.com/dp/B0DGL8HSW...f8df&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWwy&th=1
I have a silhouette that has one of those on the top that swings to either side of the head. I forget the thickness but its rated for 30-06 at 100yds. Its a lot of fun and I'll be getting one of the tree's in the near future. A .22 won't budge mine but a 9mm will move it with authority. just hit it with some orange spray paint at the end of range day and it's good to go for the next time.
https://www.amazon.com/Highwild-Tar...hwild+ar500+steel+hostage,aps,337&sr=8-7&th=1
I will say it is HEAVY and not something I'd want to take to/from a range very often.. Thankfully mine can just stay in place.
I own a tree. They are fun, and worth the money. I have 1000s if not 10s of thousands of rounds on my second one. Sometimes portions crack, where the AR500 is cut at a right angle.
Get one.
I don't have a dueling tree but I have several of the spinning targets. They are fun also. I like the ones with a small top and big bottom. I used to be able to keep them spinning but haven't been able to for a while. Every now and then you turn them around and start pounding the steel back the other way after it gets dished or if someone hits a 22 rated one with a larger caliber.
