Any Lithium Ion replacement for this motorcycle battery?
Suburban Washington DC
I'm using it in a Lotus Elise and even with only 180 CCA it starts fine but was wondering if there is a lithium ion direct replacement? At 8 pounds it took a good 25 pounds out of the car and at just $32 I'm not complaining, but if a L.I. model has some more CCA's, that would be nice.
Yes.
Go to Amazon and search "12-BS Lithium". It'll give you a start as to what you are looking for.
If your picture is accurate, you are looking for a 12-BS.
Yes.
I see this one https://www.amazon.com/Lithium-Replaces-YTX12-BS-RSV1000R-Motorcycle/dp/B07VN6F8RP
but the picture says 330 CA and description says, Cranking Amps: 250. No mention of CCA. Then under About this item, it says Weighs only 3.45 lbs, but under Product details it says 8 pounds. Does Amazon have a place to ask the seller a question?
