gd9704 Joined Feb 16, 2009 Messages 239 Location N.E. Ohio Mar 23, 2011 #21 I used 2 qts when I did mine. Just make sure you wiggle the unit around to make sure it's full before you bolt it back in...there's no easy way to check the level once it's back on the tractor!
P ponchonutty Thread starter Joined Mar 9, 2011 Messages 42 Location ohio Mar 23, 2011 #22 Thanks for the heads up. I read the entire post on here and saw that it was fun to get every drop out of the rear end.
