Any companies that make trailer enclosures?
OH
I have a small utility trailer that I used to use for hauling small things, but the enclosure has deteriorated and is not useable anymore. My wife bought the trailer when I was TDY (still in the military) and it is just that...a trailer frame, it had no box, rails, or flooring on it...I had to build the box out of 2 x 4s and plywood (and paint). I believe the box was about 6' long and around 3.5' wide. It works well, but it just doesn't last very long, and it's a pain in the boot to have to keep building them. Are there any companies that make boxes/enclosures for these trailers out of something that will last a while that you can just bolt onto the frame?
Originally Posted By: ag_ghost
Maybe call this outfit to see if they can recommend someone near you?
http://www.ohiotrailer.com/
Kevin
I looks like they make the entire trailer, but not just the box to put on a trailer...
I'm guessing it'd be cheaper if you just made your own. Again.
I used a sheet of, err, some flooring that was supposed to go ten years with paint on my trailer. Made it only to nine, but good enough. I decided to paint it this time to see if it would last longer. Pressure treat 2x4, those are still fine. The zinc plated hardware isn't, but will work for a couple more years.
