Nope.quote:
Originally posted by Filter guy:
Does removing the drain plug and oil filler cap to let the oil out and let air in, before removing the filter, have anything to do with your question Pete......
Some, not most. Most GM filters are vertical(or close), but very few don't have ADBVs.quote:
Originally posted by Triple_Se7en:
Most GM vertical AC filters are not equipped with an ADBV. My AC Delco PF-59 is one example.
Yes, if you poke a hole in it before removing it from the filter mount.quote:
Originally posted by Pete C.:
Hey guys, can a filter (any brand/manufacturer) have a PROPERLY working ADV and still be empty when you take it off the engine/mount?
Before Ya'll jump all over this, put on your thinking caps and think about it.
I played around a little with the one on my Ecotec. The element has a part sticking down with an O-ring. When you remove the cap, the element comes with it allowing more oil to run out leaving the element empty and cleaner to remove. With the element out, oil will run down to the crankcase. In place, and you can fill it with oil. There must be an ADBV somewhere, defeated when you remove the element. You could prefill that way. I don't because I think it is more important to clip the element to the cap correctly than any benefits of prefilling. I am sure the bypass is much like other in the block GM product.quote:
Originally posted by y_p_w:
I'm somewhat curious as to how various cartridge filter assemblies handle anti-drainback/anti-backpressure.
It seems possible. If you have the threaded side mounted down on an engine, the oil could slowly leak through the media through the oil passages.quote:
