After reading a lot of good info on the 132, I thought I'd give it a try with the XL7500 (old formulation - all PAO)I'm currently using. This oil, like M1 and many others, is formulated to a relatively low initial viscosity. It takes a beating in a high heat and sheer application like my turbo. Last analysis showed it down to a 20wt in 3600mi.
Car: 02 Volvo S40 10,629mi
Oil: Amsoil XL7500 10w30 filled in late Sep. 12oz of Schaeffer 132 Moly EP added in Nov at 1820mi. Car was driven 30 miles then sample taken at 1850mi.
WEAR METALS
Cu: 2
Fe: 3
Cr: 0
Al: 1
Pb: 0
ADDITIVES
Mo: 10
Ph: 863
Zn: 901
Mg: 30
Ca: 2937
CONTAMINANTS
Antifreeze, Fuel, Silicon: all zero (below detectable values)
H2O: 0.3%.....(I think I can explain)
OIL PROPERTIES
Visc: 10.23Cst@100C
Sulfur: 17
Oxidation: 0
Nitration: 3
The purpose of this analysis was to determine the increase in viscosity the 132 gave this oil which started out at 9.6 from virgin analysis. Wear was good with the previous fill of XL but viscosity dropped out of range really fast. A small ammount of Moly was added (10ppm). This additive also contains antimony at about 2.5x the moly concentration. The antimony uses a similar binding mechanism so total something like 35ppm organometalic FM's added by the 132. Viscosity shows that the whole 16oz could have been added to the 5.5qt of oil.
BTW: I am certain that the water is due to my own sampling error. I took the sample on a rather damp evening. It started to mist while I was transferring oil to the bottle in an unsheltered location. Not surprised if a few droplets landed in the bottle. Otherwise no reason to suspect water....no antifreeze and no reason for condensation.
[ December 04, 2002, 09:40 PM: Message edited by: mormit ]
WEAR METALS
Cu: 2
Fe: 3
Cr: 0
Al: 1
Pb: 0
ADDITIVES
Mo: 10
Ph: 863
Zn: 901
Mg: 30
Ca: 2937
CONTAMINANTS
OIL PROPERTIES
Visc: 10.23Cst@100C
Sulfur: 17
Oxidation: 0
Nitration: 3
