2001 Chevrolet Tahoe 5.3L V-8 stock engine. 6 quart sump capacity. Schaeffer's #701 5W-30 synthetic blend API SN. NAPA Gold oil filter. Airaid open element NON-oiled air filter. Mix of highway and short trip driving during fall/winter months. 5,131 miles on oil, 105,282 miles on engine. Oil was changed at the signal of the oil life monitor, and saw service of about 4 months. This is the second run of Schaeffer's in this vehicle, and the first oil analysis performed. 6 ounces of Neutra #131 was used in the previous fill to purge the crankcase and run over 500 miles before changeout. Blackstone performed the test.
4FEB2012
Aluminum-2
Chromium-1
Iron-24
Copper-6
Lead-5
Tin-3
Moly-338
Nickel-1
Potassium-1
Boron-10
Silicon-17
Sodium-291
Calcium-1907
Magnesium-23
Phosphorus-845
Zinc-877
SUS [email protected]
cST [email protected]
Flashpoint F-405
Fuel-<0.5
Antifreeze-0
Water-0
Insolubles-0.3
TBN-1.6
Viscosity is definitely low, and Blackstone attributes this to shearing. I don't know how this family of engines behaves, whether oil shearing is common. There is some piston slap on cold start-up, but not as noticeable as some engines I've heard. I do have a virgin sample of the current fill of this same oil sent in for analysis to see what those numbers are. The cost of this oil was $5.65 a quart full retail.
