This is a friends Tbird. The mileage was put on in a 15 month period. I lost track of time and so did she. The oil filter is a Wix and a Carquest air filter. This thing is a piece of cake to change the oil and filter on. Most of her driving is about a quarter mile from her house to the place she works and in that distance is three stop signs. It might get out on the open road once in a while but not often. It has had three oil changes so far with AMSOIL, the first one was using XL and the last two are with the OE.
Code:
Most wear looks good in the first sample from your Thunderbird. Iron was above average, but with all other
wear reading normally, we don't think it cause for alarm. It's hard to say why it might be high on this first sample, but
since everything else is perfectly fine, let's just see if it's going up or down next time. It might resolve itself. No fuel or
coolant was found and the viscosity read normally for a 5W/20. Insolubles show excellent oil filtration. The TBN read
1.1, so there's just a little active additive left. Use 5K mi again to monitor. Averages are based on 5,400 miles.
OIL OEF5w-30
MILES IN USE 5,004
MILES 28,806
SAMPLE TAKEN 07/20/13
ALUMINUM 4
CHROMIUM 1
IRON 36
COPPER 9
LEAD 0
TIN 4
MOLYBDENUM 77
NICKEL 1
MANGANESE 2
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 126
SILICON 14
SODIUM 7
CALCIUM 2227
MAGNESIUM 10
PHOSPHORUS 679
ZINC 801
BARIUM 0
INSOLUBLES 0.1
WATER% 0.0
FLASHPOINT ºF 425
SUS VIS 210ºF 53.3
cSt @ 212ºF 8.27
Fuel%
Antifreeze% 0.0
TBN 1.1
Code:
OIL OEF5w-30
MILES IN USE 5,004
MILES 28,806
ALUMINUM 4
CHROMIUM 1
IRON 36
COPPER 9
LEAD 0
TIN 4
MOLYBDENUM 77
NICKEL 1
MANGANESE 2
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 126
SILICON 14
SODIUM 7
CALCIUM 2227
MAGNESIUM 10
PHOSPHORUS 679
ZINC 801
BARIUM 0
INSOLUBLES 0.1
WATER% 0.0
FLASHPOINT ºF 425
SUS VIS 210ºF 53.3
cSt @ 212ºF 8.27
Fuel%
Antifreeze% 0.0
TBN 1.1
