Amsoil Dealers- Some Specs for me?
NW Ohio
I can find EaO filters to fit all my engines but one... My 826 , Neuss D350 power IHC tractor. Filter applications are few for this engine anyway, as it uses a 1-12 thread. The Wix number is 51768. The nominal micron rating is 25 for that filter but no Beta is given.
Donaldson, Baldwin and Fleetguard have filters. The only of this group that offers one in a "premium" line is Fleetguard, which has a Stratapore option. I was able to obtain the Beta for the Fleeguard LF3919 Stratapore, which is B30=200... rather uninspiring overall.
I'd like to see if any of the EaO filters might have some characteristics that could adapt but I can't find any information that lists physical specs. If someone could point me to a place that may list those specs, I'd be grateful.
Another option, of course, is a bypass setup, but I'd also liek to find a better primary filter. Thanks.
There's no 1-12 application for an EaO filter. As you can see it's the thread for a Jaguar and some (other) Ford products. Amsoil offers a MANN.
Part Number: 57302
UPC Number: 765809573024
Principal Application: Ford Thunderbird (03-05), Lincoln LS (02-06), Land Rover (05-09), Jaguar (06-09)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.225
Outer Diameter Top: 3.095
Outer Diameter Bottom: Closed
Thread Size: 1-12
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=16/25
Burst Pressure-PSI: 375
Max Flow Rate: 12-15 GPM
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.840 2.480 0.210
vs. spec'd filter
Part Number: 51768
UPC Number: 765809517684
Principal Application: ABG Construction Equipment, Bomag, Case/IHC, Deutz Engines, Deutz Tractors, Komatsu, Mitsubishi, Poclain
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Thread Size: 1-12
By-Pass Valve Setting-PSI: 10-12
Burst Pressure-PSI: 300
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 25
Gasket Diameters
15314 2.834 2.462 0.175
W71329 MANN xref's to the spec'd filter.
Here's all the Donaldson offerings in a "lube filter". I swore that there were some hydraulic filters that also had bypass valves, but they didn't show up in my search.
Qty Item Number Item Description Attribute Description Attribute Value
P502032
LUBE SPIN-ON FULL FLOW
A - OD (Inches) 4.25
B - Thread Size (Inches) 1-12
C - Length (Inches) 5.14
D - Gasket OD (Inches) 2.9
E - Gasket ID (Inches) 2.15
Product Type Description LUBE SPIN-ON COMBINATION
Primary Application ISUZU 8941432050
P502060
A - OD (Inches) 3.96
C - Length (Inches) 4.92
D - Gasket OD (Inches) 3.92
E - Gasket ID (Inches) 3.48
Relief Valve Setting (PSI) 11-17
Anti Drain Valve (Y/N) Yes
Product Type Description LUBE SPIN-ON FULL FLOW
Primary Application MAZDA TFY014302
P502080
A - OD (Inches) 4.02
C - Length (Inches) 5.91
D - Gasket OD (Inches) 3.91
E - Gasket ID (Inches) 3.46
Primary Application MITSUBISHI 32B4000100
P502085
A - OD (Inches) 4.21
C - Length (Inches) 3.96
Relief Valve Setting (PSI) 18-24
Primary Application MITSUBISHI 32A4000100
P550317
ELEMENT, LUBE SPIN-ON
A - OD (Inches) 3.74
C - Length (Inches) 8.31
D - Gasket OD (Inches) 2.8
E - Gasket ID (Inches) 2.4
Relief Valve Setting (PSI) 34-37
Primary Application RENAULT RVI 5000670671
P550362
LUBE SPIN ON
A - OD (Inches) 3.75
C - Length (Inches) 6.99
Relief Valve Setting (PSI) 30
Primary Application DEUTZ 1174419
P550409
Primary Application MAZDA SL0223802
P550422
A - OD (Inches) 4
C - Length (Inches) 5.92
Relief Valve Setting (PSI) 17
Primary Application HITACHI 4183853, ISUZU
Primary Application 2 8943212191
P550710
LUBE FILTER
A - OD (Inches) 3.7
C - Length (Inches) 3.75
D - Gasket OD (Inches) 2.85
E - Gasket ID (Inches) 2.45
Primary Application KOMATSU 600-211-6140
P550719
LUBE FILTER
A - OD (Inches) 3.73
C - Length (Inches) 4.22
D - Gasket OD (Inches) 2.78
E - Gasket ID (Inches) 2.43
Relief Valve Setting (PSI) 20-24
Primary Application IHC 3136046R93
P550731
LUBE FILTER
D - Gasket OD (Inches) 2.82
E - Gasket ID (Inches) 2.42
Relief Valve Setting (PSI) 18-23
Primary Application FORD E7HZ6731A (BRAZIALIAN
Primary Application 2 CAB FORWARD)
P551262
LUBE SPIN ON
A - OD (Inches) 3.67
E - Gasket ID (Inches) 2.47
Primary Application NAVISTAR 1808896C1
P551297
LUBE SPIN ON
C - Length (Inches) 6.88
Relief Valve Setting (PSI) 18-21
Primary Application KOMATSU/KOMATSU DRESSER
Primary Application 2 6002115213
P551604
SPIN-ON LUBE FILTER
A - OD (Inches) 4.37
C - Length (Inches) 8.98
D - Gasket OD (Inches) 2.81
E - Gasket ID (Inches) 2.46
Relief Valve Setting (PSI) 18-20
Primary Application FIAT 71909137, IVECO 01901604
P552411
A - OD (Inches) 3.694
C - Length (Inches) 6.987
D - Gasket OD (Inches) 2.729
E - Gasket ID (Inches) 2.415
Primary Application CASE 528250R1
P552819
LUBE SPIN ON FULL FLOW
A - OD (Inches) 3.66
C - Length (Inches) 5.35
Primary Application DEUTZ, CLARK, HYSTER
P553712
SPIN-ON LUBE FILTER
C - Length (Inches) 6.85
Product Type Description SPIN-ON LUBE FILTER
Primary Application CARRIER, ATLS COPCO,
Primary Application 2 THERMOKING 11.3712
P553771
LUBE SPIN-ON
C - Length (Inches) 7.87
Relief Valve Setting (PSI) 35
Anti Drain Valve (Y/N) yes
Primary Application DEUTZ 1174421,, CASE IH
P553871
SPIN-ON LUBE FILTER
A - OD (Inches) 4.252
C - Length (Inches) 6.61
Primary Application THERMOKING 11.3871
P555616
SPIN-ON LUBE FILTER
Stand Pipe (Y/N) Yes
Primary Application IHC 675616C91, CASE
P555680
SPIN-ON LUBE FILTER
Primary Application CAT 9N-5680
P557207
SPIN-ON LUBE FILTER
Relief Valve Setting (PSI) 7-10
Primary Application IHC 427207C2
P558250
SPIN-ON LUBE FILTER
A - OD (Inches) 3.81
C - Length (Inches) 6.78
Primary Application IHC 528250R91,
I would put all my effort in the air filter and its seal .I just don't see the big deal about oil filters when it cones to real life other that doing super extended oil change intervals with out a filter change, then a Bypass filter would extend the oil life if you were getting into it that far ? How big is your area you farm? farms and ranches to me are some of the coolest things there are.
Gary: Thanks for the extra homework. I had all the Donaldson stuff (as well as Baldwin & WIx) but the Mann was a gem... looks to be better than the Wix and even the Stratapore! Smaller, though, but all other specs look comptable
SteveS: The air filter is so good that air can barely get through!
Have been "evilly influenced" by a number of SAE papers and studies on the importance of oil filtration. This factor may be as, if not more, important than the actual oil used. I'm looking into the most cost effective ways I can implement this that I can, including filter changes every other oil change, etc.
I am currently on a 2 year, 100 hour OCI but given that this engine has 8300 hours, I would like to get as much soot out of the oil as possible, hence the bypass idea. I have a filter base and a lot of fittings. May build my own setup.
I farm just 45 acres. More than a hobby, less than a job. A "jobbie?" I run it as a business and costs are important. I like to pay myself burger-flipper wages at least.
