Hey I managed to cut open the used by-pass element that I recently replaced from the F150. This element is the 8" media AKA BE 110. Amsoil makes 3 different sizes a 6,8, and 10" spin on filter for the by-pass systems. The 10" is the size of the actual filter and you can see in the photo's the media is 8". You can tell there is quit a bit of surface area for filteration as the oil enters from the outside of the filter and goes inward where it returns to the engine/sump. This is known as radial flow filtration.
When you scroll through the photos you will notice that the disks are darker on one end. My theory is this is the part of the filter that did the most filtering. The lighter colored disks probably had alot more life left in them. I had this filter on for 2 years and 20,000 miles attached to my 4.6L Triton V-8 F150.
This spin on by-pass filter element is in my opinion one of the best designs that I've seen. It is very easy to change and lasts a long time. I know the elements cost a bit more but over the long haul easy of maintenance, oil drain interval, and equipment life outweigh just about any other filter on the market.
If you have any questions let me know
http://f1.pg.photos.yahoo.com/ph/saxnflute/album?.dir=/Amsoil+By-Pass+Filters
