amsoil ATM 10w30 virgin sample result
pb
stl
oil shipment received may 2014
iron chromium aluminum copper lead tin vanadium 16
silicon sodium 15
potassium titanium 0
molybdenum 129
nickel 0
manganese 1
boron 174
magnesium 70
calcium 4746
barium 0
phosphorus 389
zinc 1581
nitration tbn 8.7
oxidation 25.1
v40c 70
v100c 11.4
vindex 156
389 seems a bit low for the phosphorus.
silicon sodium 15
molybdenum 129
nickel 0
manganese 1
boron 174
magnesium 70
calcium 4746
barium 0
phosphorus 389
zinc 1581
nitration tbn 8.7
oxidation 25.1
v40c 70
v100c 11.4
vindex 156
That P must be an error given the high Zn and that this EP is a compound, unless something other than classic ZddP - which I couldn't imagine - is in this formulation. ATM has been a great longlife oil std by which others are measured.
What will be the application?
fwiw, the result on my 10k mile sample (also ATM) came back 378, and zinc 1466.
i use it in my 3.8 windstar and 4.0 sohc exploder.
Originally Posted By: BrianC
What Lab did this analysis? This looks nothing like AMSOIL Signature Series ATM.
Zn is high, P is low, Calcium is WAY high, TBN should be 12+.
I would call them a tell them to try again.
All AMSOIL Signature Series oils have similar add packs. See ASL 5w30 here:
http://www.pqiamerica.com/2012 April results/Amsoil.htm
MFA oil, columbia, mo
yeah i was surprised too, that's why i shared.
Interesting.
The VOA on the ATM that I had done on 13/11/09 has the following.
Zn 807
P 643
B 263
Mo 46
Mg 13
Ca 3201
Your viscosities are high as well.
Mine shows 59 cSt @ 40 C and 10.4 cSt @ 100 C.
I would agree that something's not right with your results?
Multiple used oil analysis show the Zn consistently being consumed at a disproportionately higher rate to the P the longer the oil is in service. Just saying for future reference.
yeah, it's free so perhaps it's not as accurate as it should be. i've ordered some wix kits off amazon, will be sending some from the same batch and report back here.
silicon sodium 15
molybdenum 129
nickel 0
manganese 1
boron 174
magnesium 70
calcium 4746
barium 0
phosphorus 389
zinc 1581
nitration tbn 8.7
oxidation 25.1
v40c 70
v100c 11.4
vindex 156
received results from wix/ als today. sample came from same gallon jug.
iron 1
chromium lead copper tin 1
aluminium 7
nickel silver titanium vanadium silicon 9
sodium 6
potassium 7
magnesium 6
calcium 3477
barium phosphorus 728
zinc 842
molybdenum 156
boron 243
vis 100C 9.6
vis 40C 60.9
tbn 10.9
silicon sodium 15
molybdenum 129
nickel 0
manganese 1
boron 174
magnesium 70
calcium 4746
barium 0
phosphorus 389
zinc 1581
nitration tbn 8.7
oxidation 25.1
v40c 70
v100c 11.4
vindex 156
iron 1
aluminium 7
sodium 6
potassium 7
magnesium 6
calcium 3477
zinc 842
molybdenum 156
boron 243
vis 100C 9.6
vis 40C 60.9
tbn 10.9
so i ran the differences by percentage, and i'm considering the WIX lab's # more likely to be correct (since it's $18 and the other was free).
aluminum 86%
vanadium -1500%
silicon 89%
sodium -150%
potassium 86%
molybdenum 17%
boron 28%
magnesium -1067%
calcium -36%
phosphorus 47%
zinc -88%
TBN 20%
v40c -15%
v100c -19%
Still way off on viscosity and TBN. Stick with Blackstone or Polaris/Oil Analyzers.(same thing). TBN should be 12+. Vis. @ 100C should be 10 to 11.
isn't OAI owned by amsoil?
just spoke to amsoil tech svcs, no amsoil doesn't own OAI.
as to why I have lower TBN numbers... http://www.pqiamerica.com/TBN.htm
he said the D4739 test (hydrochloric acid) will generally report new oil 2pts lower than actual.
Quite right.
It depends upon the testing method.
Anyway it doesn't matter, as long as the results of subsequent used oil analysis relating to the oil from the machinery being assessed, don't show anything abnormal when testing is always performed at the same lab.
That's the whole point of the whole process.
Originally Posted By: Ducman
Quite right.
2 things.
i suppose that is why OAI is not offering this oil analysis value kit, meant for what you mentioned.
secondly, "trust, but verify." I want to independently know that what i'm spending $xx for can prove it's ability. that why i sent a 3rd sample to OAI and will post it's results once received. i'm not one to constantly drink the koolaid without pausing from time to time to make sure it's still just that.
