Amsoil ASL 5W30, 7.5K, 12 Jeep Wrangler
Texas
First full run with Amsoil Signature series oil. This oil was changed when the Jeep oil light came on at 7,500 miles.
Make/Model: Jeep Pentastar 3.6L v6
Vehicle: 2012 Jeep Wrangler Unlimited Rubicon
Code
OIL Ams ASL 5w30 Toy 5w30
MILES IN USE 7,543 4,283
MILES ON UNIT 72,826 65,283
SAMPLE TAKEN 5/11/19 9/12/18
MAKE UP OIL 0 0
ALUMINUM 3 3
CHROMIUM 1 1
IRON 10 8
COPPER 9 10
LEAD 0 0
TIN 0 1
MOLYBDENUM 178 51
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 1
POTASSIUM 3 1
BORON 49 13
SILICON 16 16
SODIUM 11 9
CALCIUM 1252 1900
MAGNESIUM 761 221
PHOSPHORUS 650 683
ZINC 725 793
BARIUM 0 0
SUS @ 210F 60.4 53.5
Visc @ 100C 10.34 8.33
Flashpoint 395 415
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.3 0.2
TBN 3.5
Blackstone comments:
These are some nice results! Even though you ran this oil a good deal longer than the last, there's hardly any more wear to show for it. The 3.6L Pentastar powering your Jeep looks like it had no problem with the additional miles, and the oil itself held up well, too. Its viscosity is still in grade, no contamination was found, and the TBN is a strong 3.5 (1.0 is too low). The air and oil filters did a good job, too, based on the normal levels of silicon and insolubles. This all adds up to an ideal report, so feel free to run the next oil even longer. Check back after ~9,500 miles.
Blackstone comments are good. (They aren't always!)
Healthy engine with a great oil. No bad numbers. Could have gone another 3,000 miles with that high TBN at the end.
Originally Posted by dhellman12
Amsoil ...This oil was changed when the Jeep oil light came on at 7,500 miles.
Using higher-spec oils than what the engine computer software algorithm (OLM) assumes you're using, especially in a low-soot port fuel injected engine, means you could possibly go about 1.5x the dashboard light time and miles. I'd use a Fram Ultra XG10955 to match the performance of AMSOIL Signature Series, Mobil 1 Extended Performance, Mobil 1 Annual Protection, Castrol EDGE Extended Performance, Ravenol DXG, or Rotella T6 Multi-Vehicle in there.
My 1.5T DI gasoline 'soot-maker' (GM 2018) defeats just about any oil at 7,500 miles according to GM.
On that run I was using a Wix filter. On this run I switched over to the Amsoil EA as I'd assumed the report would show it would be safe to extend the OCI out even further.
Thanks - areyou planning 9500 ... or further?
