vehicle----------04 Toyota Tacoma, 2RZ-FE, 2.4L, 4 cyl
OIL-------------5 qt, 20 oz Amsoil ASL 5w-30
oil additive------6 oz LC20 at oil/filter change
oil filter----------Amsoil EAO57
air filter---------Fram, new at apprx 30,000 miles
miles on oil/filter------8,346 (apprx 7 months--12/13/06 thru 7/4/07)
miles on vehicle--38,198
UOA by Oil Analyzers:
iron-------------------9
chromium-------------0
lead-------------------0
copper----------------13
tin--------------------0
aluminum-------------1
nickel-----------------0
silver-----------------0
silicon----------------19
boron----------------127
sodium---------------0
magnesium------------22
calcium--------------3506
barium---------------0
phosphorus-----------698
zinc-------------------900
molybdenum-----------54
titanium---------------0
vanadium-------------0
potassium------------0
fuel visc40---------------n/a
visc100--------------11.31
water----------------0
soot/solids----------n/a
coolant--------------NO
change---------------YES
nitr------------------22.0
oxid-----------------15.0
TBN------------------3.52
anaysis recommendations---"NO CORRECTIVE ACTION REQUIRED, OIL IS SUITABLE FOR CONTINUED USE. RESAMPLE AT NEXT REGULAR INTERVAL"
NOTES/COMMENTS:
This is my brother's truck. Probably around 60% highway, 40% city. Apprx 3,000 miles towing apprx 1300# trailer. Plugs are original (were due for change at beginning of this OCI). He purchased truck with apprx 10,000 miles on it. Since then he changed Castrol GTX 5W-30 & conventional oil filter every 5,000 miles til last oil change which was apprx 4,500 miles on Mobil1 EP with Mobil1 EP filter. FP60 added to non-top tier gas apprx every other tank. Don't plan to use LC20 with 100% synthetic oil again.
Currently using ASL with 3 oz maintenance dose of Auto-RX, Amsoil EA oil & air filters. I expect he'll be changing plugs any day now--when he can figure out how. I expect the EAA air filter to drop the silicon & hopefully the iron & copper. The high copper has me puzzzled. Other than the high copper, looks like the ASL oil & EA oil filter did a good job keeping wear in check with high silicon.
FUTURE PLAN:
NO LC20 with this oil. Resample at 10-15,000 miles. Run oil/filter to around 15,000+ miles. Possibly change to Amsoil HDD 5W-30 if wear not noticeably improved. Stick with Amsoil EA filters. Continue Auto-RX maintenance dosing if UOA's positive.
PREVIOUS ANALYSIS: none
Comments appreciated.
NOTES/COMMENTS:
FUTURE PLAN:
