Fluid was replaced at time of sample.
Make/Model: GM Differential (Front)
Vehicle: 2004 Chevrolet Tahoe
Oil Analysis Comments:
The front differential on this Tahoe appears to be in very good shape, with low wear metal readings giving us no reason to suspect any internal problems. Iron, indicative of steel wear, is exceptionally low for the miles. The oil tested to be in good condition, as well, with viscosity appropriate for 75W/90, and no sign of significant water or dirt contamination. Solids (insolubles) read low at 0.2%, indicating very little oxidation due to heat, and the TAN of 2.3 shows that little acidity built up. Feel free to try 60,000 miles next time and check back then to see the effects.
Code:
OIL Amsoil 75w90 Amsoil 75w90 Unknown MILES IN USE 45,029 29,386 Unknown MILES ON UNIT 203K 158K 123K SAMPLE TAKEN 4/25/16 11/8/13 5/3/11 MAKE UP OIL 0 0 0 ALUMINUM 1 2 7 CHROMIUM 0 0 1 IRON 85 133 346 COPPER 3 5 8 LEAD 0 1 1 TIN 2 0 0 MOLYBDENUM 2 9 82 NICKEL 0 2 4 MANGANESE 1 2 5 SILVER 0 1 0 TITANIUM 0 0 1 POTASSIUM 0 1 0 BORON 106 95 89 SILICON 31 36 38 SODIUM 1 2 4 CALCIUM 6 12 80 MAGNESIUM 0 2 10 PHOSPHORUS 891 862 579 ZINC 22 41 90 BARIUM 0 0 1 SUS @ 210F 67.3 78.6 56.0 Visc @ 100C 12.23 15.16 9.07 Flashpoint 415 415 370 Water % 0.0 0.0 0.0 Insolubles % 0.2 0.2 0.3 TAN 2.3 1.7 NA
