Car: 2004 Pontiac Sunfire
Engine: 2.2L Ecotec
Total Engine Miles: 149,492
Oil Type & Grade: Amsoil 5w30
Oil Use Interval: 7,984 miles
Sample Date: 01/13/09
-- Universal Averages in Parenthesis () --
Aluminum -- 2 (2)
Chromium --- 0 (0)
Iron ----- 8 (9)
Copper --- 3 (2)
Lead ----- 0 (0)
Tin ------- 1 (1)
Molybdenum - 49 (49)
Nickel ---- 1 (0)
Manganese -- 0 (0)
Silver --- 0 (0)
Titanium --- 0 (0)
Potassium -- 3 (2)
Boron ----- 160 (49)
Silicon --- 5 (6)
Sodium ---- 8 (14)
Calcium --- 3167 (2352)
Magnesium -- 14 (88)
Phosphorus -- 635 (703)
Zinc ------- 775 (839)
Barium ---- 0 (0)
Viscosity at 210F -- 59.7
cST Viscosity at 100C - 10.13
Flashpoint in F -- 395
Fuel Percentage -- less than .5
Insolubles --- 0.3
TBN ----- 4.1
Notes from Blackstone: 'Looks like you're sticking with 8,000 miles on the oil, and this Sunfire is still wearing very well. Miles are steady and low, same as they have been over the last couple of years. You can see your own averages in the unit/location column. Your engine makes less iron than most, but other than that it wears exactly the same as other GM 2.2L engines. The TBN read 4.1, higher this time than usual. Factors such as driving conditions can affect a TBN. No contaminants were present in this sample. Looks great!'
My Notes: ' I can feel a difference between Amsoil 5w30 ASL and Amsoil 5w20 XL. Definitely prefer the lighter weight oil. Engine feels like it has more lower end torque and more "sporty" through the RPM band (much more willing to go past 4,000 rpms). I used Amsoil ASL 5w30 because I had 3 quarts of it left over from an earlier oil change. Amsoil 5w20XL is back in the crank case.'
Engine: 2.2L Ecotec
Aluminum -- 2 (2)
Chromium --- 0 (0)
Iron ----- 8 (9)
Copper --- 3 (2)
Lead ----- 0 (0)
Tin ------- 1 (1)
Nickel ---- 1 (0)
Manganese -- 0 (0)
Silver --- 0 (0)
Titanium --- 0 (0)
Potassium -- 3 (2)
Silicon --- 5 (6)
Sodium ---- 8 (14)
Barium ---- 0 (0)
Insolubles --- 0.3
TBN ----- 4.1
