Amsoil 5W-30 HM VOA
Here’s more Redline Service Chemicals
Those are relabeled Phillips 66 products.
Why even mention these products if you are concerned about the Amsoil oil properties?
Just info sir Don’t get excited
If you’ve need seen these products how do you know there just relabeled ???? Chill out
Confusing info compared to BS
Moly is up 6
Boron down 31
Ca is down 6
Mag is down 133
Phos is down 5
Zinc is up 139
Vis is up .74
Make sense of this
Moly is up 6
Boron down 31
Ca is down 6
Mag is down 133
Phos is down 5
Zinc is up 139
Vis is up .74
Make sense of this
Number one is putting much any faith in a $25 analysis - it is not one up or one down.
Number Two is large margin of error for metal spectroanalysis in fact P is amazingly close on the two. Most are quite close actually.
The one thing that should be repeatable is viscosity. Looks like Blackstone missed the mark. Amsoil typical is 11, so 10.7 is fairly close, under 10 seems off.
there is such a thing as slight blending variance's that may happen to every blender/manufacture of lubricants, long as the required parameters and specifications are met, nothing to be overly concerned about. and analysis labs can and do vary some , just will give you a good general accuracy of a idea in most cases of your needs.
True. We notice, for example, that Schaeffer doesn't list a single number for viscosity. They list a small range.
I should add that I have no comment on whether those ranges are 'good' or 'bad' with respect to what other blenders do. I simply note it's listed as a range, but the range is less than the full range of the J300 grade allowance.
Just got back the sample. What do you guys think
I don't know what you expect to see.
Typ LL/olm style product, a little high overbase, wouldn't not run this high detergency if not running it out 10K + miles.
Also not on a D.I gasohol engine.
That;s just me(?) biased against LL unless spec or need.
It’s was nothing more than a comparison between BlackStone and Lake Speed testing to see the difference in real world testing
You got to see the numbers for free
So take it at face value and pick whichever you like
