Analysis done by pdma lab. Thanks and plug for pdma first analysis is free
Amsoil 10w30 Synthetic. 12,318 miles on oil; Filter change at 6000 using Amsoil Filter.
Dodge Avenger 1996 v6, 80,000 miles on car. Last oil change was also Amsoil. Various oils before that.
Results
Wear Metals ppm
iron 10
chromium 0
moly 1
alum 0
copper 14
lead 1
tin,silver,nickel,vanadium,titanium,manganese,
cadmium = all 0
Contaminant metals ppm
silicon 5
sodium 8
boron 0
Additive Metals ppm
Magnesium 271
Calcium 1598
Barium 0
Phosphorous 942
Zinc 1244
Non-Metallic %vol
Solids 0.5
water Nil
Fuel
Lube Data
Viscosity@100c -cst- = 12.5 no idea..
Total BASE Number -ml- = 1.12
Infared au
Hydroxy 0.027
Antiwear Loss 1.211
Oxidation 1.039
Nitration 2.121
Comments
Severity = N - Normal
Recommended Action = "Continue Sampling to track/trend data"
Data Interretation = "Based on results...lube appears satisfactory for continued usage"
Can anyone help with deciphering all this?
My observations. The Air-K&N/Oil-Amsoil filter definetly doing great job here. Only 5ppm Silicon!
But what is with that low TBN? And how can they recommend continued use when it looks as if the oil is beyond its useful range? What is that Viscosity Number?
So from the looks of it, Amsoil held up and is ready for more! I live in Dusty Vegas also and do mostly stop/go driving. I recently switched to Havoline after this oil change thinking Amsoil wasn't worth it and dino was just as good. But this and the extended drain interval may make me go back.. Extended was the main reason I even went the Amsoil route. But I should test the Havoline dino I used now in 5000 to make comparitive judgements. It may hold up just as well in this engine. I suspect the Amsoil Oil filter really had a great impact on these excellent results.
Any thoughts, comments?
Results
Wear Metals ppm
iron 10
chromium 0
moly 1
alum 0
copper 14
lead 1
cadmium = all 0
silicon 5
sodium 8
boron 0
Additive Metals ppm
Magnesium 271
Calcium 1598
Barium 0
Phosphorous 942
Zinc 1244
Non-Metallic %vol
Solids 0.5
water Nil
Fuel
Lube Data
Infared au
Hydroxy 0.027
Antiwear Loss 1.211
Oxidation 1.039
Nitration 2.121
Comments
