Originally Posted By: azsynthetic
I told you the obvious answer but you refuse to hear them. AMSOIL said that their bypass do not filter out the wear metals nor the additive metals. Metal additives don't "dissolve" into the host oil because there job is to form a sacrificial layer under extreme pressure. The wear metals should be the same size otherwise the additives are not doing their job. According to ISO 23556 testing, these filters remove 39 percent of soot contaminants less than one micron so the additives and wear metals have to be smaller than that.
Additives cannot be stripped out of oil by typical filter media. There are some cases when EPs and/or antifoaming agenst can be stripped out if not fully solublized, but that is a failure of the blending process and not the fault of the filter media. As a generalization, additives cannot be stripped out when the additives are properly mixed, and the media is typical of FF and BP media. Here is some info specific to additives:
http://www.machinerylubrication.com/Read/28711/filters-remove-additives
it acknowledges that additives can be stripped, but when you read about the methods used, they do NOT represent the type filtration we are talking about with a traditional bypass filter set up. Like I've said, GENERALLY, (given the methods we're speaking of) the additives are not stripped out when all is working correctly.
But ...
Filters are "dumb"; anything that is large enough to be caught in their pore structure, will be; they cannot discern between a 4um soot particle and a 4um particle of Al, Fe, Cu, etc. So, if a wear metal particle is 4um in size, the bypass filter is likely to catch it. Hence, if the filter can pull out a wear metal particle, it can skew the UOA data.
I would point to this article that supports my position:
http://www.machinerylubrication.com/Read/28799/removing-wear-particles
Note that the question in italics is about filtration of oil from an off-engine device (bypass filter) regarding lube additives and small wear particles. Specifically, the question is about the relationship of wear metal evidence being removed from the UOA, and the pre- and post-filter analysis with regard to wear metals in the answer! My position is that when we talk of small wear particles that can been seen in a UOA (sub-um up to 5um) and we talk of BP filters that are extremely efficient somewhere around 2um and on up, the BP filter has an extreme ability to effect the UOA depending upon where you sample, and a lessor (but still very statistically meaningful) effect on the overall sump load when it comes to particles of any composition, even wear metals! That is the EXACT topic of this link I provide here.
And there's this:
http://www.machinerylubrication.com/Read/28592/filter-quality-oil-analysis
Note that they talk about how filtration effects cleanliness and the question is specific about contamination and Fe wear. The answer (while not directly stating it, implies it) that ...
The higher the beta for the same micron pore size will result in a faster cleanup rate. Thus, it is better able to control ingression of solids in the system. The main system ingression sources typically are seals, breathers and oil top-ups, and wear debris." "Solids" means not just soot, but also metals (Fe, Al, Cu, Tn, Pb, etc) and he specifically mentions
wear debris. In short, the tighter the filter, the more able to catch anything, and that INCLUDES metals.
And there's this about "The advantages of bypass filters":
http://www.machinerylubrication.com/Read/28508/bypass-filters
This speaks to the bypass filter taking out both organic and inorganic particles. Metals are inorganic. It says nothing of bypass filters leaving metals in the system; it speaks to fitlers being indiscriminant and catching anything within their purview.
Please quote your source at Amsoil; I'll call and ask the details, by speaking to the person (or department) that you spoke with. I've spoke with their "techs" at times before, and it wouldn't be the first time they've been wrong or mislead people (not intentionally, but by being mistaken). I've had the same experience with Wix and NewVenture. When I get a chance today, I'll call Amsoil; will you please cite your specific source?
In short, I say fitlers are "dumb" and will catch what they can catch; they cannot discriminate. You say they are selective and can discriminate between particles. It cannot be both ways.
I stand by my comments and challenge yours. I say that bypass fitlers most certaily can filter out smaller wear metal particles and skew UOA data. You specifically stated this:
You can check with Amsoil and they will tell you that the bypass filter does not remove wear metals.
I have given you several links to prove my point. There are other sources as well that agree with my position. Please leave you typical rhetoric at the door, and bring real information to the debate.
