Originally Posted By: Shannow
Originally Posted By: Jim Allen
Circular defense of thin oils?
Shannow you claim to have an engineering background. Do you also have the resources to run the same sorts of qualification tests a big company like Ford uses to certify oil? Until you do, I submit that, if you are intellectually honest, you have to give those tests a great deal of credence.
See, you have just stated that "Ford said", and anyone who hasn't the engineering resources of Ford, nor applied same to THAT question can comment with credibility.
Which in turn makes your own argument "Ford said", as you haven't the capability to independently verify.
Last time I checked, the laws of physics weren't brand specific, nor did they waver depending on how much $$$ is thrown at it.
For a given load, critical dimensions and speed, a 20 will have a lower film thickness than a 30...is it important ?
Maybe
It's important enough for Ford to be adapting their bearings to 20 weight in the ecoboost with their much higher power densities than that which they have manufactured for (probably the same decades that they've been offering xW-30)
You are reinforcing my argument here. They are evolving the viscosity requirements according to the engine and and the operating conditions. That's what they SHOULD be doing. Shows they are on the ball. That's the concept I've been trying to impress on the "thick oil fanboys."
Every engine has a "three bears" point; too thick, too thin and just right. I contend that, for the most part, the OE knows that "just right" point better than a bunch of internet theorists (of which I am but one) so I give their recommendations a lot of weight. In other words, given my limited expertise and resources, who do I trust more? A battalion of engineers at a company that has spent millions to qualify an oil viscosity for my engine, or a bunch of "so-called self-appointed oil gurus" (to quote Brigadier's description of me)? The answer seems clear to me, but obviously not to others.
Of course 20 grade has less film thickness that 30 grade. I'm not arguing that point. All I want you to grasp is that Ford went through an elaborate certification process to verify that most of their engines of were adequately protected on 20 grade. The ones that weren't, or the situations where the ones that were might not be adequately protected, are documented in the manuals. No doubt they made mistakes in some areas but the 10 years since they switched over has more or less proven them right. Whatever their motivation for adopting 5W20 oils, it's worked out just fine. Is it optimal in every case. NO! I've typed it so many times here that my already gnarled fingers are now resembling bony claws. Is it adequate in the cases where it's spec'ed, in the overwhelmingly high percentage, yes.
Can we agree on that much, at least?
I never knew how few motor vehicles there were in Australia until I checked, 16.4 million as of last year. It's entirely possible that there are more Ford vehicles on the road in the USA running on 5W20 than there are cars on the road period in Australia. In light of this incredible thread, that makes me smile. Seems certain that there are more vehicles of all types in the USA running 5W20 than there are vehicles in Australia. Interestingly, the per-capita vehicle ownership isn't all that far apart, 808/1000 in the USA vs 730/1000 in AUS.
