Just my $0.02 worth of opinion:
Why?
Seriously, why?
If you put a larger diameter pulley on the engine so as to have the alternator spin faster so it can put out more current to keep the voltage up, then you will be giving the alternator more leverage to bring down the engine RPMs even more when the increase in load from the fans occurs. Bring down the RPMs some more any you might get something to act up such as the engine stalling, or maybe even the transmission having some lag when you accelerate due to the internal oil pressure being too low caused by the lower idle?
The voltage dipping to 12.5 for a short amount of time is nothing to be concerned about unless it is causing some kind of a problem with some other electrical component such as you sound system. And most other systems such as sound will have no problem with the voltage being 12.5 Volts. Are the headlights getting so dim during the 12.5 Volt dip that it is a noticeable problem at night?
If there is no electrical component problems during the 12.5 Volt dip then why mess with something that is working just fine the way it is? If it ain't broke don't fix it. If you do you may be setting your self up for problems that may eventually convince you to put it back the way it was before you messed with it.
