well the other day at the local store, come out and my battery is dead, im like crap. so i got it jumped and it was fine, went home and tested the voltage, at idle it was about 11.3 volts.
recently (6mo ago) i checked the charging system and it wasnt really that great, numbers never went up past 12.3 so i knew my alternator was going to go out.
so i buy a new alternator and test the volts at idle...it goes anywhere between 12.6 to 13.30 which is great!!!
when my headlights are on and my stereo thevolts are around 12.9 or so. if i revv the engine it shoots to 13.2 or more
with my cooling fans on and headlights and stereo its about 12.3 if i rev the engine it shoots to about 13.1
with my cooling fans, my headlights, and my stereo and my AC its about 11.5 if i rev the engine it shoots to about 12.3
now i am letting my car sit, and notice the voltage on the battery at rest is around 12.2 which is pretty darn low i think...
so it got me thinking, and i put a new battery. (replacing the 7 year die hard)
...oh btw, there is no contamination or any corrosion on my battery terminals in case you were wondering.
now it runs at just about 14 volts at idle...
yet when everything is on with ac and lights and defog that sucker is still around 11.5 and if i revv it goes up slowly to 12 then barley hitting 13.
im beginning to think that the load is too much for the alternator to handle. i got the old alternator tested and it passed every time, so now im thinking.
what you guys think...most likley need some more amps?
i do have a thread about upgrading the alternator wire size but im not sure if this is the issue....
thank you!
thank you!
