The 2011 Duramax owner's manual supplement states that when
operating in very cold climates use Allison KS295 approved synthetic ATF.
That got me looking for an Allison 295 ATF.
Mobil Delvac, (likely the FF) is approved for Allison's extended warranty.
Chevron (2008 product book) lists a "289" ATF and their HD synthetic
295 approved, but not for the extended warranty program.
Petro-Can has a 295 approved synthetic, but no mention of warranty.
As far as I can tell, the Allison is not fussy, but I think that the FF
of Dexron 6 is misguided, and will be the first thing to go on my next new truck.
I ended up using Petro-Can's Dura-Drive syn, because that is what I had in my stash.
Parking the truck up hill I managed to drain 9 liters out of the transmission
including the spin-on filter.
The torque converter holds 4 liters that will never drain out.
If I was to switch to the Mobil product, I would disconnect the cooler return line
and run a couple of liters through the system.
One question...Is 295 backward compatible to Allison 289 approved fluids?
