Originally Posted By: Doug Hillary
HDEOs were and still can be best at minimising deposits rather than "cleaning up and engine" when used correctly. Some brands of HDEOs are better than others at controlling their main contaminant - soot!
Modern PCMOs of the correct specification are wonderful products - especially those that have a dual rating of say SM/CF. The Brand matters very little in real terms
Perhaps, Doug, you might be able to provide a suggestion or two with a little dilemma I'm having. I recently had a Ford 300 from a 1984 F-150 rebuilt. The previous owner treated oil as a lifetime fluid. He rebuilt the engine, but never cleaned out oil galleries, put in rings upside down, and other miscellaneous little gems. It was a sludgy, leaking, oozing mess with low oil pressure.
In that, I ran a number of very low OCIs (under 3,000 miles) for about two years, I'm guessing 5 or 6 oil changes. I wanted it to be clean for another planned rebuild. I even threw one can of solvent flush in there once, knowing full well what harm could be done, but in mind that a rebuild was planned anyhow. In any case, when the engine was taken apart, it was absolutely spotless, although the oil galleries still weren't perfect.
Now, with my 1991 Audi 200 2.2L I5 Turbo, I recently did the valve cover gasket. The pictures with the valve cover gasket off are
http://www.bobistheoilguy.com/forums/ubb...921#Post1943921 for your reference. Most of the deposits are hard and granular; I'm not sure if one would consider that run of the mill sludge, or what.
I've done a few short OCIs with that (unsure of the previous history of the car; I've had it for just over two years). I've used Delvac 1 ESP 5w-40, Delvac 1300 15w40, and some RP 0w-40 and Mobil 1 5w-40 for some winter use. I put Pennzoil Conventional 10w30 in after changing the valve cover gasket and running the engine for a period. Most of the time, however, it's eben on Delvac 1 and Delvac 1300. I have GC available for my next OC.
So, any suggestions or comments? I'd love to hear from Doug, but anyone and everyone else is welcome and encouraged to chime in.
