Ahh, got it. Are the disks/database all in the same location? If so, what happens if the building they're housed lost power or burned to the ground?You are not understanding. The sentence you highlighted in bold was not a backup or disaster recovery scenario. It was members in a cluster in the same location sharing the same disk drives. All the systems are sharing the workload. You can pull out one system at a time to update it. The other systems in the cluster pick up the workload. When one system is returned to the cluster another one is pulled out of the cluster. Over a few hours all the systems have been pulled out, updated and started back up again. All the systems in the sysplex share the same set of disk drives/database. No movement of data within the sysplex.
Scott
