hi. i have a 2000 hyundai accent 108,000 miles. mechanic told me i needed an mass air flow sensor. dealer price $218 he says it's the only place tp get it. does anyone know of anywhere cheaper way to go? and how difficult is it to install? thanks.
With all due respect to mcnabj, this is one of those parts I would never buy used. It's too delicate. I like Kestas' idea better. 90% rubbing alcohol (as compared to 70%) with a Q-tip will also work. You need something that won't leave residue behind.
Q tips could produce too much force, as many seem to be fine wire wound around a glass or ceramic core. I used a Testor's model paint brush, which worked fine as it produces very low force. Use some magnification to check cleanliness.
definately try the cleaning route first, contact cleaner thats maf sensitive should do the trick if it infact isn't broken or anything. if it is try the junkyard route. usually the m.a.f. is in-line after the air filter somewhere but before the intake manifold so that narrows the location possibilities. just locate where the wires in that area go.. boom there it is....
44H
autozone has one for $104,$30 core charge.only thing warehouse is out of stock. there are some online available i found around same price. the car idles rough after setting over night,then smoooths out after about 30 seconds. sometimes there is a slight "cutout" when in a pull.
i found one,about $100 with core trade in.lifetime warranty.it looks easy to install,looking at where the it plugs in. i hate to ask a dumb question,but before i go prying on the plug in,can someone tell how to unplug it?looks like it snaps off,but not sure,thanks,george
