Air Filter life span
What does the owner's manual suggest? That is usually a good starting point. I might roll that back a bit, based on visual inspections. Most of my cars it ends up being 15k to 20k, only because they are relatively inexpensive, so I am totally fine with replacing a bit early. I am sure they could go 25k to 30k without significant performance loss.
My experience. 2018 Santa Fe Sport 4Cyl. 12,000 miles a year. Owner's manual recommends E 30,000 miles. But, with highway driving it's black at 15,000 especially in a dry year or desert driving. Cabin filter needs changed every year.
2006 Camry 4 Cyl. Owner's manual says change at 15,000 miles. Actual milage closer 10,000 to 12,000. Cabin filter changed every year, two at the most.
I purchased Microgard cabin filters for the above cars both made in USA. Air seems cleaner in both cars.
What does the owner's manual suggest? That is usually a good starting point. I might roll that back a bit, based on visual inspections. Most of my cars it ends up being 15k to 20k, only because they are relatively inexpensive.
And that's a great point. It's much cheaper to replace a filter than to waste gas, lose performance and whatever else comes with a clogged engine air filter.
Unless one frequents gravel roads or other dusty areas, an engine air filter with only 20k miles won't likely lose measurable performance, and is even less likely to "waste gas" in a vehicle that's recent enough to have closed-loop mixture control. When I replaced the air filter at about 110k miles in a car that was older than that (the Mazda listed below), I couldn't discern any change in fuel consumption or power.
127k miles now on the filter in my Prius.
Over the decades, I've settled on 30k for both.
Never has either been real dirty.
Also, those restriction gauges are of questionable usefullness.
Members here report that the engine air filter has to be extremely clogged for the thing to move to yellow or red.
Also, there aren't many flat surfaces for drilling the mounting hole in today's heavily contoured intake systems.
I also worry about the filter developing a tear, which would allow unfiltered air through, and not budge the restriction gauge. And so I like to remove the filter and inspect it every year or so.
Here's two examples of my recent purchases. I say these were installed for too long. One due to miles/time & the other Volvo due to time. The engine with the turbo (Navigator) had the worst dirt load. Application is certainly part of the equation & the manual is a good guide.
Here's what 74k & 9 years looks like:
Here's what 28,500 miles & 9 years looks like:
I recently posted that I had changed an air filter out @ 20K miles. It was dirty looking but not super clogged, mainly some debris and dead bugs. I was told that changing that filter out was too soon. ( i didn't mention that we bought the car with that filter in it so unknown as to how many actual miles on it) . We do have gravel/oil chip roads here in southwestern Illinois but mainly paved roads and highways. What is the general consensus on air filter life spans under normal driving conditions?
Run it till the foam rips or the paper turns black.
My Mercedes dealer recommended that the air filters be changed at 52,500 miles. I bought Mahle filters from FCP Euro and changed them myself.
That 74k filter looks far worse than the 110k and 127k filters I mentioned in post #25. Which only goes to reinforce the point that conditions are a bigger factor than mileage.
Right, just shows some folks have no issue neglecting simple maintenance. It sounds like your Prius is easy on filters so if neglected can be better. I'll check the Navigator at 25k or so & see if it'll go further or not but age certainly deteriorated the foam on the Volvo. It crumbled very easily.
... It sounds like your Prius is easy on filters so if neglected can be better...
True, because 1)the intake is in a relatively well sheltered spot; 2)It uses the same filter size as other Toyota models that consume a lot more air per mile; 3)I don't go off pavement much.
Much the same was also true of my 1981 Mazda. After its filter size became hard to find, I switched to filters for 2.8 liter GM V-6 engines of similar vintage.
I was speaking of air filters and not cabin air filters. My 2006 Lincoln did not have a cabin air filter but my wife’s 2005 PT cruiser has one, go figure. I have seen videos online of testing where they measured filters that use oil and were too restrictive and others that would barely stop a robin from getting into the engine. The actual winner of the test was a Fram filter for overall efficiency and filtering.
Myself, visual appearance is what determines if replacement is warranted
Your eyes tell you nothing about a air filters condition.
You need to install a restriction gauge..... and go by that.
You'll be shocked by how far a airfilter will go, for city driven cars.
My LZ0
