I am frustrated because two weeks ago I put in new plugs, (as well as, new PCV valve, air filter, and air breather filter), and now it doesn't start right up like it normally does. It takes a couple of tries, which I know is not good for the engine. I have a 93 Ford Econoline with 300 6 cyl engine. The plugs are correct, the gap is correct. The parts store sold me the BSF 44 C (motorcraft) which is copper. The parts guy said it was what the van came with originally. I do not recall what plugs I had in there before. Any ideas why it doesn't start like it normally does after changing plugs? I assume it is related to the spark considering that I just put plugs in, and that's when the problem began. But can it also be related to fuel or air? (I did change the filters....). Should I take out the plugs and replace them with a different brand, or maybe a platinum plug? My van has 175K on it. The wires, cap, and rotor are about two years old. Thanks for any suggestions.
