Have had this airplane for about 2.5 years, the engine was factory new when I got it. It only takes 100LL and is in an Experimental Cub. Doing analysis in part because the IO-360 gets morning sickness on cold starts (coughing/chugging for 3-5 seconds). On advice of mechanic added Marvel Mystery Oil to Fuel at 1 oz per gallon along with Camguard in the oil at the specified amount (1.5 oz per quart) during oil changes. This worked for awhile but if the airplane sat long enough without running (1 week +) it would still have the problem. He also recommended I switch to straight grade Aeroshell W100 (SAE 50) or W80 (SAE 40) oil (seasonally dependent) but I haven't done that yet because in Alaska I value the 15w rating of the Aeroshell 15w-50 for cold starts. He said the straight weight scavenges lead better.
On the 9/28 sample an experienced friend recommended that I put 1 quart of MMO in the oil instead of a top off quart of Aeroshell at about 30 hours into the OCI. I guess that caused the low viscosisty and I stopped doing that.
The mechanic told me he thinks the #2 exhaust valve guide is sticking on cold starts because that valve runs the coolest due to its position in the engine cowling, and that lead doesn't fully pass through the exhaust system if the temps aren't high enough. I lean fuel mixture aggressively during ground ops and in cruise while respecting 380F CHT. Even so it is an Alaska airplane and the CHT's in cruise often can't get much higher than 310-330 even with cowling modifications.
