Aerodynamics are key to electric vehicle (EV) efficiency and driving range. The basic principle is simple; the lower the coefficient of drag (cD), the further you can travel per charge.
I think the VW XL1 hybrid prototype had a Cd of just 0.159. I am unaware of anything lower in the automotive world. The drag coefficient of the limited production version has increased slightly from 0.186 to 0.189.
Sort of a silly comparison, but a Cessna 172 (going by memory) has a total zero lift aircraft Cd of less than 0.03. And about 6 square feet of "drag" area.
it's pretty useful. Frontal aero doesn't very that much among categories of cars. I mean, you're correct,you can't measure CdA without "A", but the reality is that if you're comparing similar cars, the one with the lowest Cd is almost always going to have the lowest CdA.The List is not really useful, we only have half the data there, also need Frontal Area.
https://www.caranddriver.com/features/a15108689/drag-queens-aerodynamics-compared-comparison-test/
Take a look at the list at the bottom shows how frontal area and Coefficient of Drag play a role.
I think it's pretty key. A 10% reduction in drag= a 5% increase in range. Take something like Volvo's XC40, which is basically a legacy product that's been electrified, and a Cd of .34, and compare it to a ground-up EV in the same category, a VW ID4. The Drag is Cd is .28, and front area is roughly the same--so drag is likely about 20% less. That equates to at last 20 extra miles per charge. That's pretty significant (and at higher speeds, when you're likely to need the range more, such as long trips, that number is going to increase since power requirements increase at roughly the cube of speed).I understand that aerodynamics are an important part of an EV's range but don't know that I would go so far as to call them "key".
Otherwise we would see a lot more extreme designs. But what we really see in many cases is a manufacturer's existing model like an SUV or pickup truck with a battery added. Not exactly vehicles known for a low CD.
Regarding the EV's lack of requirement for a large opening for a radiator and intake grills for brake cooling, we know that manufacturers already have a lot of "fake" cosmetic features on cars. Like dual or quad exhaust tips that when you look under the car prove to be for style rather than function and huge scoops and intake ports or in the case of Hondas, fake grills on the rear of the vehicle. What a joke.
Anyway, Tesla has done a good job styling the Model S front end to look more traditional, they need to do something with their pug nosed Model 3 and Model Y too. A "fake" piece of chrome or something imitating a conventional grill would go a long way towards improving their appearance.
My friend's drop dead gorgeous BMW i8 plays engine noise through the radio. Debbie thinks it's stupid. She loves the car; who wouldn't?There were a lot of those. The most egregious was the 90s Mustang that looked like a hood scoop but had some hex patterned plastic piece.
But tradition is weird. I’ve heard some EVs even pump in a fake exhaust note.
They need the noise outside. In certain situations a EV can creep up behind a pedestrian. Those can be dangerous and deadly for the person if they don’t know the car is behind them.
This is a pretty good piece on Cd if you can stomach Cammisa.
On the Hyundai products it's an electronic device with an amp and speaker that responds to speed and vehicle direction off the CAN network. It's not actually a recorded sound but synthesized chords. The person in the video also made his own, here.... I can hear a whoosh style sound. ... Not sure how this is done as an add on for a Tesla, but I heard many of these are factory setups.
A lot of the ICE car aero drag comes from air going into the hood and under the car (say the bumper cover scooping air like a spoon in a bowl of soup).
There is much less cooling need for an EV, the engine requires a lot of air around to cool it in addition to the radiator, and the air flow around exhaust manifold and pipe all the way also requires a certain amount of air flow to keep things cool. Removing that need means EV can be much more aerodynamic, blocking air going under the hood and under the car. Without exhaust pipe also means the whole area can be covered up as long as the suspension movement is not impacted.
Wheel wise, hybrid should be about the same as EV, but you still need enough worst case cooling going downhill on an already full battery. You don't want an overheated brake so you still need to size the airflow for the weight of the vehicle in an EV, or find a way to dump that heat from regen downhill traffic into the radiator.
