Originally Posted By: gfh77665
Originally Posted By: cashmoney
Tires will get flat spots if unmoved for long periods of time - get it up on 4 cheap jack stands or just roll it a couple of feet so every couple of weeks so its on different part of tire.
Sorry, but NO, do not do this! Modern tires will not permanently flat spot, but even if they did, DO NOT jack your car up. Thats an old myth that causes damage to suspensions - suspensions that were made to be loaded. DO NOT jack your car up.
I am perfectly happy to be wrong here but we need to see where you get your information that modern tires do not permanently flat spot and where your information comes from that putting a car on jack stands for long term storage damages suspensions. Please post some data and sources supporting the fact that modern tires do not flat spot and that storage of car long term on jack stands damages suspension. I expect different points of view, and there appears to be some debate - I just like to see something more definitive from a more authoritative source (not other misc folks posting on forums) on statements like this.
Here is one source for my opinion - Recent tech article from Tire Rack.com
Minimizing Flatspotting
While there is no way to completely avoid tire flatspotting, knowing what to expect under different conditions will help minimize its inconvenience.
NOTE: It is important to check and reset tire inflation pressures to those recommended by the vehicle manufacturer on the vehicle placard or owners manual when taking a vehicle out of storage.
Tire flatspotting would be most noticeable when beginning to drive a vehicle that has been stored incorrectly (with the weight of the vehicle pressing down through the tires to the ground). When storing a vehicle for more than a few weeks, it is best to drive the vehicle until it is thoroughly warmed up and then immediately put it up on "blocks" after arriving at the storage location. Doing this takes the load off of the tires completely. Not doing this on a vehicle that will be parked for a few months runs the risk of permanently flatspotting the tires.
Tire flatspotting may also be noticed when beginning to drive a vehicle that has not been driven for a few days, or during the colder winter months after the vehicle has been parked overnight. However, these types of flatspots will usually disappear during the first few miles of driving.
Usually during the day, the warmer ambient temperatures and more frequent vehicle use will not allow noticeable flatspots to form. However, anytime a vehicle goes in for ride-related services (tire rotation, rebalancing, or to diagnose ride disturbances), the vehicle should be driven for 5 to 10 miles immediately before being raised in the shop to make certain that temporary flatspots are not preventing the source of the ride complaint from being isolated and corrected.
And finally, tire flatspotting will also be noticed at the beginning of each session when attending a driver's school, track day or race. Whenever the car is returned to the paddock, the vehicle should immediately be lifted off of the ground to prevent flatspotting (this will also allow the car to feel more stable at the beginning of the next track session). This practice also allows debris to be cleaned off of the hot tires while they are inspected for any punctures and cuts. If you watch the professional race teams at an event, you'll see that they always remove the race tires immediately after stopping in the pits at the end of a session (if they plan to continue using the tires).
