Adventures with a 2 stroke Mantis
Marshfield , MA
I gave up last yr and used a spade fork instead. Don't wanna do that again. The other day, I happened across thread on the Tractor Forum saying that a cruddy off switch failed shut. "nother guy chipped in saying to sand the magnets too. BTDT, but I hadn't thought of it. I was about to find a coil. I first drained the yr old gas pulled the plug and tried for spark. couldn't see one ,but got a tiny, almost pleasant, tingle. Time to sand the magnets . The coil is one legged with 2 magnets? I managed to sand that too. I pulled the shut off wire off just to eliminate it. I put the starter on and pulled it over. Blue spark. I put the plug in. I got it to pop several times, but not catch. Thats where I left it. Come day light, I'll find the B 12 and add an oz or 2. The TF is 40:1 ,so the Mantis should handle it OK. I'm gonna let that soak overnight before I get serious with the carb. It has a Chinese clone of the original Zama. More later when I get some results
I was given a Mantis that sat for years with E10 gas in it. The carb passages are so tiny as to be "unclearable" so I am buying a new carb. Thanks for the tip about sanding the magnets. Will try that if the spark is weak.
Yah me too. I had the carb off it. I pulled the starter to take a look at the piston. It lit right off and scampered down the bench. Most Ive had it running to date
It's alive!! 3rd carb did the trick. getting the huge grommet onto the tank was a PITN. Inorder to get it on, I had work it on without the hoses. I used a piece of lashing cord half hitched around the bitter ends to pull them through. Now to straighten out the throttle cable at the trigger to relieve its binding.
