As far as i know this tractor has been garaged for either most or all of its life. I remember it when i was a child in the late 90s early 2000s and it was always garaged then. It has only ever had the 46” deck and it was used only to mow grass. I just put a model 43 front blade on it that i got from a 110 square fender on Craigslist. Still has what i believe are the original good year tires on the back. Front arent original as they wear out from turning. Only modification i made is put the 2 brake pedal system in from a 318/322/332. I still have the parts to put it back to stock but i get stuck too often without the dual brakes.very nice and very clean. Love the 300 series, have a few 316, couple 318 and a 400. No Diesels though.
330 is a awesome kinda rare unit. What implements do you have?
Looks like the original Goodyear Softrac out back there. Had a set on a 316 when I got it. Looks to be in great shape original paint. Very nice thanks for sharing a pic.As far as i know this tractor has been garaged for either most or all of its life. I remember it when i was a child in the late 90s early 2000s and it was always garaged then. It has only ever had the 46” deck and it was used only to mow grass. I just put a model 43 front blade on it that i got from a 110 square fender on Craigslist. Still has what i believe are the original good year tires on the back. Front arent original as they wear out from turning. Only modification i made is put the 2 brake pedal system in from a 318/322/332. I still have the parts to put it back to stock but i get stuck too often without the dual brakes.View attachment 133897
Might be a little smoother but it’s hard to tell.Did it run better or different after the adjustment?
Yeah the best part is definitely the fuel savings. It normally takes me around 3 hours to mow and i can get two mowings per tank at full throttle. I couldn’t imagine how much gasoline it would take.Nice! I had a 1992 332 with the 3cylinder Yanmar diesel w a 3 point hitch, ag tires, turning plow, bagger, and a front mount dethatcher. It was a beast that just sipped fuel, and I never should have sold it!‘My tractor forum‘ under the GT section is a wealth of knowledge.
